Home > Off Topic > House Alarm Engineers...? |
T code is a tamper code. If you join the tamper wires together or reconnect the PIR you should be able to clear the fault |
14th Mar 2011 11:21am |
Paulo Member Since: 28 Sep 2010 Location: Glasgow Posts: 199 |
Thanks John,
14th Mar 2011 12:54pm |
Lookers Park Royal Member Since: 30 Apr 2008 Location: London Posts: 463 |
I had the same fun and games with mine (different alarm though) when we had our hall replastered. One still showed 'tamper' even when it was refitted, but upon inspection the microswitch had moved slightly in the case and was not making a connection.
14th Mar 2011 3:31pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
As it happens, I'm an security/alarm engineer by trade, as rightfully said above, closing the PIR cover or shorting the tamper pair inside the PIR will clear the fault. Depending on how your system is configured, it may be set for engineer reset, it shouldn't be though. If it is, you will need the engineer code entered to clear the fault. You might hit lucky if it's the default code still, off hand, I think the sequence you would need to do if it's the default code is, 0 enter 7890, if it goes into engineer mode, the led's will flash, then to exit, key in 99 enter.
14th Mar 2011 6:04pm |
Thanks guys, will keep you posted once I re-fit them to the walls and try out your fixes.... |
15th Mar 2011 9:45am |
