Home > Maintenance & Mods (L405) > Strange metallic noise
Sester
United Kingdom 2014 Range Rover HSE SDV8 Santorini Black
Hi all,
When accelerating steadily and the car changes gear, as the revs drop, I can hear a metallic spinning noise ?
If I drive it hard it’s not really noticeable.
It’s sounds like some metal part in the engine bay behind the dash ?
Any idea please ?
Post #545674 1st Mar 2020 3:20pm
Baltic Blue
It’s a wild guess, but their are several fan motors behind the dash... eg
De mister fan motor
Post #545676 1st Mar 2020 3:31pm
Sester
Thanks so much for the reply.
I’m almost certain it’s not those as it’s in the engine bay and is Rev’s related !
It’s only when accelerating ?
It’s not owt to do with the turbo spool is it ?
Post #545677 1st Mar 2020 3:47pm
Sester
Update !
I’ve had the bonnet up and it’s air related not metallic!
It’s a strange sucking and blowing noise wen I rev the car but it’s really loud coming ftt try on the drivers side rear and side corner under the bonnet ???
Wen you rev, as it settles it’s a spinning sound and there’s a blow / suck of air but it’s really loud ??
Any ideas please ??
Post #546231 6th Mar 2020 7:28pm
Sester
Just seen a post saying it could be turbo hose ??
Can anyone tell me where this is situated and is it easy to get too ?
That is, at least to check....
Post #546232 6th Mar 2020 7:39pm
Sester
This is where the loud sucking noise is coming from on the offside
This air box is also where the noise is on the offside.
There is no noise or sucking from the near side vents or air box
Post #546287 7th Mar 2020 12:40pm
Sester
Yellow exhaust nearly full warning come on.
Took for a blast on motorway.
💥 red triangle 🔺 restricted power now 🤬
Limped home, god give me strength 😭😭😭
Post #546299 7th Mar 2020 2:34pm
jackcramerr
All diesel cars suffer from dpf and egr issues. It can be fixed.
Some diesel cars blow head gasket with clogged dpf and egr. More expensive cars I am assuming, go into limp mode before this can happen.
If dpf and egr is clogged then Diesel is not the engine for you to begin with.
Post #546306 7th Mar 2020 3:14pm
Greyskull
England 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Did you get it sorted out ?
Post #550034 11th Apr 2020 8:51pm
