![]() | Home > Technical (L322) > Heated Steering Wheel, how hot should it get |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2567 ![]() ![]() ![]() |
The few times that I've used mine I've turned it off after no more than 5 minutes due to being more than hot enough. |
ikjos Member Since: 09 Sep 2019 Location: Hornindal Posts: 41 ![]() ![]() ![]() |
I use mine almost every day. It gets nice and warm but not too warm. Could be a faulty temp sensor.
Bluegreygreen Rangie 2 Member Since: 27 Feb 2020 Location: Australia Posts: 74 ![]() ![]() |
If you have a gap diagnostic tool or possibly another type you might see the engine load raise when you turn it on. if so you could monitor it and see if the thermostat is working
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
When the steering wheel is worn it can get too hot. |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 595 ![]() ![]() ![]() |
Thanks everyone, I guess that the best thermostat is my thumb!
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 ![]() ![]() |
Hi All,
