Home > Technical (L322) > Heated Steering Wheel, how hot should it get
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hello everyone
I accidentally turned on my heated wheel yesterday and noticed that it got very hot, so hot that I had to turn it off, so suspecting that the thermostat has failed I thought I would ask the question how hot should it get?
I know that this is subjective so will get hold of a thermometer and measure it, but does anyone know what temperature it should reach?
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #545285 27th Feb 2020 12:57am
GraemeS
The few times that I've used mine I've turned it off after no more than 5 minutes due to being more than hot enough.
Post #545287 27th Feb 2020 2:38am
ikjos
Norway 2012 Range Rover Westminster 4.4 V8 Santorini Black
I use mine almost every day. It gets nice and warm but not too warm. Could be a faulty temp sensor.
Reminds me of a snowmobile we had at work once, also with heated handlebars. The temp sensor failed and melted the gloves of my colleague Shocked
Post #545297 27th Feb 2020 8:45am
Bluegreygreen Rangie 2
Australia
Re: Heated Steering Wheel, how hot should it get
If you have a gap diagnostic tool or possibly another type you might see the engine load raise when you turn it on. if so you could monitor it and see if the thermostat is working
The above might sound silly however i noticed that at idle my heated front windscrean adds about 5-6% to the engine load (via alternator) when i tun it on
Dave 2010 3.6TDV8 Autobiography
Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 275/55/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #545325 27th Feb 2020 1:47pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
When the steering wheel is worn it can get too hot.
Post #545327 27th Feb 2020 1:57pm
bigbo
Thanks everyone, I guess that the best thermostat is my thumb!
I'll keep an eye on it. Next time I'm playing with my icarsoft I'll see if I can look at engine load. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #545334 27th Feb 2020 2:40pm
Anvil
Hi All,
Mine takes quite a while to heat up, and then seems to have warmer spots in places than others. Should it be pretty uniform? Is there more than one element in there perchance?
Not a huge issue but I do like to know these things!
Hope all out there in FFRR land are well......
Si.
Post #546085 5th Mar 2020 2:54pm
