Home > Technical (L322) > What could be the source of a whirring noise from here
Simmoto
United Kingdom 2010 Range Rover Vogue TDV8 Rimini Red
Got a whirring noise, present in Park or Drive. It's not there for the first 10 minutes from cold but gets progressively more noticeable as the engine reaches temperature. No dash warnings.
I used a stethoscope to try and find the source and it is only audible roughly in the yellow oval. Tried loads of other locations but no whirring.
What could be whirring at this location (drivers side cylinder bank)?
Thanks
Post #544740 21st Feb 2020 9:49pm
Need to zoom out a bit There is nothing that can't be fixed with a hammer😜😜
Post #544751 22nd Feb 2020 7:28am
Simmoto
Sorry, poor photo. Yesterday i thought it was coming from the middle of the below pic (under the 90 degree flexible inlet hose), today I can't hear anything!
Post #544767 22nd Feb 2020 10:18am
mpirie
Dry belt tensioner or alternator bearing?
Does the noise change with engine speed?
Mike
Post #544874 23rd Feb 2020 9:09am
Simmoto
Thanks Mike, yes I was thinking something on the accessory belt. Has an alternator 5 year s ago (only 15K miles though) so I was thinking tensioner. My local garage diagnosed a wheel bearing but I can hear this at idle in Park. It might need a bearing too but it can't be the whole problem. Think I'll take it to a specialist. To answer your question, no the noise seems pretty constant. It's not AC related as have tried turning that off. Could it be intake/exhaust leak or a gearbox/transfer box type issue? New fluid?
Post #544879 23rd Feb 2020 9:50am
mpirie
If you're hearing the noise at the top/front of the engine, it's unlikely to be the gearbox fluid.
My money would be on the belt tensioner, they seem to go at around 60-70k. Normally they're noisy at startup and as the engine heats up, the bearing goes quiet. You would be able to hear it on the move and stopped, though they normally change noise when the engine speed changes.
Mike
Post #544915 23rd Feb 2020 4:20pm
Simmoto
Thanks Mike Thumbs Up
Post #544924 23rd Feb 2020 5:00pm
