![]() | Home > Maintenance & Mods (L322) > 2009 TDV8 Battery AGM or not |
PeeJayBee Member Since: 04 Feb 2011 Location: Halifax Posts: 7 ![]() ![]() |
Hi, looking for help in deciding which type of battery my RR needs. I bought a 2009 3.6 TDV8 Vogue SE 3 years ago from a non-LR Dealer. He had fitted a new 019 AGM type battery which now needs replacing, which seems a little soon to me, and if I sit in the car with the radio on the "Low Battery" message pops up almost immediately. I have checked the charging voltage at 14.2V. When I previously took the car into my local Indie dealer for service, he said I had the wrong battery and the AGM was only introduced with the 4.4V8. Other people have said all MY2010 L322 need AGM. My car is 2009, but has LCD dash and push button start and I beleive it to be a MY2010. Loging in to totalcarcheck says it is a 2010. Can anyone tell me if there is a definitive way of knowing which type of battery my car needs. I have read many of the threads on here, and found many interesting opinions/dabates about the advantage of each, but I would just like to fit the correct battery as designed. Thanks |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
Do you have Stop-Start? That's the main reason an AGM battery will be introduced. 2016 Skoda Octavia VRS Estate
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I understood that the AGM battery was introduced with the digital instrument display and that these cars have a different charging software. So the earliest cars with AGM are 3.6's and do not have stop start.
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
There's two types of stop/start compliant batteries. AGM & EFB.
You may well be right. What I was trying to say (not very clearly) is if you have stop-start, AGM would definitely have been the original fitment. That's not to say that earlier, digital dash 3.6s didn't have it too. 2016 Skoda Octavia VRS Estate <gone>2009 FF Vogue TDV8 Buckingham Blue</gone> <gone>2015 BMW 520D SE (not my favourite car)</gone> <gone>2009 D3 HSE Galway Green</gone> |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
I installed an AGM in my 07 TDV8, and I'm very pleased with the result.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1356 ![]() ![]() |
Went from a normal 020 battery that gave up the ghost after 18 months to an 019 agm.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
I wasn’t aware any L322 had stop/start, so that shouldn’t be a factor.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
As I understand it the 2009 facelift (3.6TD and 5.0, then the 4.4TD in 2010) which has the LCD dash included a revised charging system to address tendency to drain.
Wow, looks like it’s around £450 for an 020 Bosch AGM.....
Sorry for confusion in that case. I thought it was fitted to 4.4s and potentially some of the digital dash 3.6s. 2016 Skoda Octavia VRS Estate <gone>2009 FF Vogue TDV8 Buckingham Blue</gone> <gone>2015 BMW 520D SE (not my favourite car)</gone> <gone>2009 D3 HSE Galway Green</gone> |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Based on my previous post regarding my battery/alternator issues, I took my old battery back to ECP to swap under warranty. As luck would have it, their system was down, so I managed to get an AGM 019 for £60.
