![]() | Home > Technical (L322) > Rain water release from back passenger doors |
ShuntL322 Member Since: 21 Dec 2019 Location: Acle, Norfolk Posts: 18 ![]() ![]() ![]() |
At the bottom of the doors there’s some open bits. Mine were bunged with leaf mold. Washed it out an all
http://www.fullfatrr.com/forum/topic12101.html?highlight=water |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
One of my rear doors done this as well. What I done was cut a 5mm x 10mm piece of bike inner tube (or similar bit of rubber) and neatly glue it at the middle of the bottom door seal (glue it around the curve of the seal, so to speak). Creates a tiny gap between the door seal and body when door is closed, and the water can drain out. Problem solved. |
