Home > Maintenance & Mods (L322) > Are you sick of worrying about a flat battery?
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Alternator. I had a drain on my old D3 for ages, couldn't find it. Alternator was putting out over 14v so thought it was fine. Eventually, I worked out that the alternator diode pack had failed and it was putting out an AC voltage, as well aa the DC.
With the engine running, measure battery voltage using AC setting on multimeter. Should be zero. Mine was about 0.75v AC I think. New alternator sorted it.
Post #543755 12th Feb 2020 5:59pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Just purchased one of these.
(link wont work!)
But its this on ebay Imazing Portable Car Jump Starter - 1500A Peak 12000mAH
Post #543759 12th Feb 2020 6:04pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Me too!
We were packing up the caravan and I was in and out the car, closing the doors because it was raining! So when it came to driving away, car wouldn’t start!
Had to get the warden with his battery pack!Quick jump and we were gone!
So after reading this thread, I’ve bought Imazing too! 2014 vogue se
Post #543781 13th Feb 2020 9:05am
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
Me too with the packing caravan routine, come to depart, and flat battery.
If I start my ff, and don't let it run for a while, battery flat Crying or Very sad
I've got into the habit of turning off the interior lights every time I open the doors if I'm loading the caravan, bit of a pain, but I'm sure it helps.
Post #543784 13th Feb 2020 10:13am
Wogger, if you hold the interior light button for a few seconds it will disable the interior lights permanently! Until you hold it again to re-initialise them... Thumbs Up
Easier than pressing the darn button every time you open a door sir Thumbs Up
Post #543795 13th Feb 2020 11:51am
kjmeijer
Netherlands 2011 Range Rover Supercharged 5.0 SC V8 Buckingham Blue
I have this Startzilla 2012 from Telwin. A bit more expensive but very well made.
 2011 RR 5.0 SC & 2021 New Defender D300
Post #543797 13th Feb 2020 11:55am
Wogger
Cheers Craig, you live and learn, had the motor for nearly five years and didn't realise Embarassed
Post #543845 13th Feb 2020 9:38pm
chefkenmore
Me neither!
Could have saved me a couple of shillings Thumbs Up
Well done CTC Bow down 2014 vogue se
Post #543849 13th Feb 2020 9:46pm
Post #543865 14th Feb 2020 12:12am
