Home > Maintenance & Mods (L322) > Are you sick of worrying about a flat battery?
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
After being stranded more than once with a flat battery, even after fitting a second battery and being unable to find a parasitic drain and with my alternator delivering 14.3v with the engine running I was, at my wits end.
I've invested in a lithium jump starter an "Imazing IM29 2500A" and I have to say its a godsend, the size of a paperback book, capable of jump starting an 8ltr diesel or gasoline engine, with torch and also a power bank to charge phones etc it has gotten me out of bother already, I have no connection to the product or company but I'd recommend carrying one.
One a similar topic has, anyone fitted a solar panel, similar to motor home ones to the roof? Many are low profile and flexible enabling a reasonably discreet fitting, coupled with the decreasing costs and the amount of real estate available on a range rover roof, is it plausible? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #543262 6th Feb 2020 8:35pm
scuddriver
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
I have a similar one and they are great. Gone are the days of the big heavy battery booster. Mine sits in the RH boot cubbyhole and holds its charge for months. 2011 Vogue TDV8 4.4
1992 Mazda Mx5
Post #543263 6th Feb 2020 8:48pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I keep one in my Discovery 4.They are brilliant, until the day the battery went flat and I couldnt open the doors Big Cry
Manual key lock was broken as well.
Post #543267 6th Feb 2020 9:27pm
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Out of interest, does anyone know how many times one of these would start a FF on a single charge ?
I'm guessing the manufacturer blurb will claim one thing , but anyone with real world experience?
Post #543275 6th Feb 2020 10:05pm
Sandyt
I have one and it started my p38 with a 4.6 v8 engine more than 6 times on the trot
Also mine has a lead to charge from the cigar lighter so now I tend to keep it charged up from there
Post #543276 6th Feb 2020 10:07pm
Rapiscan
Here's the device in question:
Post #543292 7th Feb 2020 12:53am
Pawl
That battery booster pack sounds very good .
I keep looking at similar devices, but haven't bought because I didn't know anyone with an RR who'd used one successfully.
Where did you buy from ?
Amazon UK doesn't appear to have them Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #543294 7th Feb 2020 1:07am
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Made in the USA, see https://imazing-power.com/products/imazing...k-21000mah
The above link is the top end model that also has an AC invertor (110V though).
Yet another reason for a swift trans-Atlantic UK-USA free trade deal! "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #543296 7th Feb 2020 1:52am
Rapiscan
Got mine for £70off ebay, its new but opened box etc, normally around £85-£110 ish... 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #543313 7th Feb 2020 11:11am
Weegie
A list of UK available:
https://kit.honestjohn.co.uk/top-tens/top-10-jump-starters/ John
GAP iiD BT-Sold
Post #543314 7th Feb 2020 11:28am
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
Thanks, just what I was looking for
Post #543340 7th Feb 2020 6:32pm
Rapiscan
Hi, no I got it from a UK seller on ebay, they are available here in UK, yes recharges from domestic 13a socket or in your car thru cigar socket, so leave it plugged in and it will always be 100 %charged.I checked mine after 2weeks left in the boot unplugged and it still shows 100%. It has 2500A peak power for starting and the internal lithium battery capacity is 25000ma.Comes in a nice rigid case with compartment to hold supplied cables/accessories. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #543353 7th Feb 2020 9:25pm
MikeLawrence
United Kingdom 2008 Range Rover Vogue TDV8 Lucerne Green
Hi All,
I've used a booster/jump pack for years now and the best one I have had is the MAC Tools one.
I've jump started my P38s with it and now I have an L322 I've used it on that too, mainly after going away for a few days and forgetting to switch off the dash cam! Doh!
After getting back from holiday a couple of weeks ago I used it on my wife's supercharged Jag XKR and it fired that up easily too. It's a bit bigger than some of the ones on eBay but I bought it directly from the MAC Tools guy so I had somewhere to return it if it played up. Been nearly two years with it now and it's great. It charges from the car, has numerous connections for laptops etc, a torch, a 19v output for computer charging and two 5v USB outputs. Love it!
The manual recommends contacting SIP Tools if MAC can't help so maybe it's a SIP unit. It wasn't cheap, over a hundred quid, but it's never let me down. Started a 600cc bike that hadn't been run for a year with multiple attempts down to 30% and still worked.
Post #543733 12th Feb 2020 3:06pm
ur20v
A Trap
Yep that’s a SIP unit: https://www.sipuk.co.uk/pro-booster-packs.html 141.17 GBP.
Post #543742 12th Feb 2020 3:50pm
MikeLawrence
Very Happy
You beat me to it! There are a few on eBay as well from about £99.00 to £140.00 I know you believe you understand what you think I said, but I'm not sure you realise that what you heard is not what I meant.
Post #543745 12th Feb 2020 4:06pm
