![]() | Home > Maintenance & Mods (L322) > iPod Connector? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Which model year ?
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 ![]() ![]() |
Its a 2005 mate |
Does it have touch screen sat nav ? |
Does so anything out there for it? |
I don't think so but someone else may know........
Yes. At the moment the only thing avail is the OEM LR Audio Connectivity Module (ACM) - which is actually listed by LR as only fitting the facelift-dash models. It does fit and work on the older models just fune, but you have to remove the upper dash panel to access the wiring at the back of the head unit. The newer models have the wiring extended to behind the glove box so it's more or less plug n play. It's not a lot of work: dis- and re-assembly of the dash can be done in under an hour. There was a thread on all of this (more than one actually) a while back with descriptions. There is also a vid on YouTube on how to remove the dash panel. All that said, there may be an alternative to the OEM ACM available in the not too distant future. Stay tuned... ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
thanks for the in depth reply very handy
The non-touch sat nav is BMW electronics - need to upgrade the radio module from a BM53 to a BM54 and then you can buy a kit from a main dealer that adds pins to one of the connectors and an extra bit of cable in the boot to provide an aux input. Then run a cable through to the centre console & pover from inside the arm rest.
For an iPod, the best solution is an intravee:
