![]() | Home > In Car Electronics (L322) > What's this remote and what's it do |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
Looks a lot like remote park heater remote. Warms your car nice and toasty before you get in it. 2016 Skoda Octavia VRS Estate
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It is for the fuel burning heater. If the battery in the fob is OK, press it within range of your car, the green light should start to flash. If the conditions are right i.e. it's cold, you have more than 1/4 tank of diesel and your battery is OK the heater will start up. Nice when the windows are iced up to walk outside 20 minutes later to a warm car and de-iced windows. BMW i3 Electric Car
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Instructions are in your vehicle manual under FBH (fuel burning heater) |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
Thanks for replies Where is the unit fitted and what does it look like, nothing happens when I press the keys, so step1 need to check even if I have a heater fitted.
M@r]{ Member Since: 03 Nov 2019 Location: Northants Posts: 165 ![]() ![]() ![]() |
When you try it, hold down the On button until you see the green led on the remote start to flash. Just briefly clicking the button won't work (assume its a safeguard feature to help prevent accidental operation)
go into your screen menu - you should have ventilation and park heating options. if heating is grey/shaded then it's not fitted.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Y
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
I’ll give you £20 for it |
No joy at the moment, thanks to you guys at least I could be heading in the right direct
I press and hold the on button, green light flashes and goes out, nothing seems to happen, should the green light stay on if its working? Where is the heater located and what does it look like? I am assuming it is fuel fired so should make a noise while running |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7909 ![]() ![]() ![]() |
Green light flashes whilst it’s working.
Try the pairing sequence again. Requires a fuse in boot removing and replacing with a button press sequence. Can't remember exactly what it is. Search function on here is invaluable |
Y
