Home > In Car Electronics (L322) > What's this remote and what's it do
yelnats69
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zambezi Silver
Anyone have any instructions
This remote is attached to my spare key.
Anyone know what it does and where I can find instructions
Post #542829 3rd Feb 2020 12:55am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
Looks a lot like remote park heater remote. Warms your car nice and toasty before you get in it. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #542830 3rd Feb 2020 1:02am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It is for the fuel burning heater. If the battery in the fob is OK, press it within range of your car, the green light should start to flash. If the conditions are right i.e. it's cold, you have more than 1/4 tank of diesel and your battery is OK the heater will start up. Nice when the windows are iced up to walk outside 20 minutes later to a warm car and de-iced windows. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #542832 3rd Feb 2020 6:12am
Dolphinboy
Instructions are in your vehicle manual under FBH (fuel burning heater)
Post #542836 3rd Feb 2020 8:37am
yelnats69
Thanks for replies Where is the unit fitted and what does it look like, nothing happens when I press the keys, so step1 need to check even if I have a heater fitted.
2011 vogue D with digital dash
Post #542838 3rd Feb 2020 8:40am
M@r]{
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Barolo Black
When you try it, hold down the On button until you see the green led on the remote start to flash. Just briefly clicking the button won't work (assume its a safeguard feature to help prevent accidental operation)
For it to work, the conditions required include sufficient fuel level (1/4 tank?) sufficient battery level and the temp below a certain level (to warrant warming) or above a certain level (to warrant some fresh air circulation) That's my understanding anyway.
Post #542839 3rd Feb 2020 8:43am
Dolphinboy
go into your screen menu - you should have ventilation and park heating options. if heating is grey/shaded then it's not fitted.
The receiver unit is in the rear (Right?) of the boot. search on here for pics etc. there is lots.
Just for your info, you do have an FBH fitted (all diesels do to get the engine up to temp) but not all have the park heat receiver fitted. you could also check your build sheet on TOPIX.
Post #542849 3rd Feb 2020 9:59am
rjff
Y
Have you had any joy with this yet? Cheers
Richard
Gap IIDBT
Post #543117 5th Feb 2020 4:45pm
DrRob
I’ll give you £20 for it Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #543118 5th Feb 2020 4:51pm
yelnats69
No joy at the moment, thanks to you guys at least I could be heading in the right direct
Will keep you posted, for now I have suspension problems,
Post #543119 5th Feb 2020 5:16pm
yelnats69
I press and hold the on button, green light flashes and goes out, nothing seems to happen, should the green light stay on if its working?
Where is the heater located and what does it look like?
I am assuming it is fuel fired so should make a noise while running
Post #543197 6th Feb 2020 10:40am
mjdronfield
Green light flashes whilst it’s working.
It’s located under the battery, in the wheel arch area. Need to take out wheel arch liner for access.
The exhaust comes out at the bottom of the wheel arch.
It is fuel driven, so sounds like a small jet when running.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #543202 6th Feb 2020 11:07am
DrRob
Try the pairing sequence again. Requires a fuse in boot removing and replacing with a button press sequence. Can't remember exactly what it is. Search function on here is invaluable Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #543210 6th Feb 2020 1:20pm
rjff
Y
To pair the remote
ensure you have a good battery properly installed in the remote
remove fuse 16 (5amp) in the rear off side fuse box
replace fuse and within 5 seconds press the OFF button on the remote for at least 1 second and release
to confirm if successful push the OFF button and red light will be continuous
if it is intermittent the pairing failed
Oh, and mine just needs the ON pushing and releasing to operate the FBH.
There's a full description of the FBH in the WM in the Wiki, climate section, and as DrRob says lots in search on here.
When you start the car on a cold morning, (without using the remote) stick your head under the rear * and you should hear a click at about 1 second intervals that increases after a minute or so to about 2 per second. That's the FBH pump running. It does so to assist in warm up time.
* the car's, not yours Confused Cheers
Richard
Gap IIDBT
Post #543250 6th Feb 2020 6:14pm
