Home > Maintenance & Mods (L322) > Will a battery be OK left for 2 weeks?
Simmoto
United Kingdom 2010 Range Rover Vogue TDV8 Rimini Red
So, I'm away for 2 weeks, will a battery in good condition still start the car after not being run or will the various systems discharge it?
I do have an Optimate but it's a minor PITA to rig it up to the RR as it's going to be outside, needs an extension and will be in the elements etc....
Cheers
Post #542769 2nd Feb 2020 1:41pm
Dolphinboy
should be ok if you top it up before you go. I have left mine many times for 2-3 weeks and never had a problem. Make sure everything is switched off tho!!
Post #542775 2nd Feb 2020 2:50pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Have left mine more than 2 wks starts 1st time. Think we should start a list who can leave it the longest Rolling with laughter
Post #542776 2nd Feb 2020 2:53pm
Simmoto
Thanks Guys, I've bottled it and rigged up the Optimate Laughing Got a charging adaptor for the towbar socket from the FF shop and found a route outside for the lead. Probably cook the battery and blow the vehicle up Thumbs Up
Cheers!
Post #542777 2nd Feb 2020 2:58pm
It really depends on how good your battery is.....
How old is it ?
Post #542778 2nd Feb 2020 3:08pm
mpirie
If the car is being left outside, another option is to get a solar panel charger (got mine from Maplins) and leave it on the parcel shelf (or wherever the sun can reach it), plugged into the boot cigar-lighter socket.
Mike
Post #542780 2nd Feb 2020 3:14pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I regularly leave mine for 1 month parked up on the drive.
I just ensure that everything is switched off, and the old girl always starts first turn of the key when I come back.
Jim
Post #542781 2nd Feb 2020 3:18pm
Simmoto
When you say everything switched off, what could be left on? I've just got the thing so not sure if there's more to it than pressing the off button! I'd just leave it single locked. Thumbs Up
Post #542793 2nd Feb 2020 5:40pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
My 2011 5.0 S/C regularly sits for 2 weeks without moving, and sometimes 3 weeks, and I've never had any issues so far. It typically does long journeys when I do use it though, so I suspect is always left as fully charged as the alternator can manage.
But obviously very dependant on the condition of your battery!
Post #542805 2nd Feb 2020 8:10pm
Simmoto
Mike
Cheers Mike, that's a good idea
Post #542806 2nd Feb 2020 8:12pm
Simmoto
How old is it ?
No record of it being changed unfortunately (but it might have been), so assuming it's 10 yrs old but then again, it's done 700 miles this week so should be charged as far as it can be...
Post #542807 2nd Feb 2020 8:16pm
jim4244
I make sure that every switch is turned off
Heater fan
Heated seats
Radio
Lights not set on auto
Etc etc etc
I don’t just turn the car off and hope for the best.
Jim
Post #542809 2nd Feb 2020 9:12pm
Mr Tee
Both my old ones struggled being left for 2 weeks, even with good batteries. Always at the airport leave everyone standing in the Censored rain as you don’t want extra draw before start. Last time it just started, newish battery freshly charged before we went. Car park roulette is what we call it. Worst part of the holidays Big Cry Thumbs Up Big Cry
Post #542822 2nd Feb 2020 11:07pm
basil
2014 Range Rover Autobiography 5.0 SC V8 Mariana Black
Mike
My query with this neat solar solution, is that if the cigarette lighter disconnects during the shut down period (mine does) then that means a relay is breaking the positive feed, so my basic logic would reason that charging would don't work?
...Jon.
Post #542925 3rd Feb 2020 10:13pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Only if the battery is on its way out. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #542945 4th Feb 2020 6:17am
