Home > Maintenance & Mods (L322) > L322 Headlight Query
PovertySpec
England 2003 Range Rover SE Td6 Zambezi Silver
Hi all - quick question, on an 03 TD6, how many electrical plug connectors should there be connected on the back of the headlight unit?
Post #542646 1st Feb 2020 2:57pm
there might be info in the WM re this.. ... - .- -.
Post #542656 1st Feb 2020 4:22pm
322BLL
Estonia
2.
Post #542696 1st Feb 2020 10:01pm
PovertySpec
I was afraid this might be the case. The wiring for the lights at the front has been a source of ...amusement.... so far and although everything appears to be working, I have a “check dip beam” error. When I took everything apart to see if I could find any obvious issues, it looked to me that there should be another plug connected apart from the main one. I’ve double checked today and it looks like someone has spliced the wiring and joined cables together.
I need to check a bit further, but I’m tempted to source a loom that hasn’t been tampered with and connect it all up properly and then see what’s what.
Post #542705 1st Feb 2020 11:05pm
PovertySpec
Right...I must admit, I’m a bit puzzled.
I’ve sourced a couple of looms so I can sort out what I believed was a wiring issue, however, on stripping the front end of the car down, and uncovering the tape wrap, what I see makes no sense. On the looms I sourced, there are 11 wires feeding 2 plugs. On my car, I have 4 wires feeding one plug. Donor loom on the left, bodge repair on mine to the right.
Everything else looks right, I’m going to try and uncover more of the loom just to make sure it wasn’t cut right back for whatever reason but unless a 03 plate diesel should only have these four wires then I’m at a loss.
Any ideas?
Post #546274 7th Mar 2020 11:24am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Begin to think somebody have change headlight units for later model.
Post #546364 7th Mar 2020 10:29pm
PovertySpec
I think I agree. Having trawled some eBay listings I have found that there is a halogen headlight, with the one single connector on.
Given mine is listed as an SE, it’s likely that it really was a poverty spec and came originally with halogen only headlights.
It would also explain why the headlight wash have no connectors on the rear for water.
Post #546368 7th Mar 2020 10:50pm
