![]() | Home > My Range Rover > New owner from RRS to FFRR ...... |
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 ![]() ![]() ![]() |
Nice. What ceramic coating did they use? |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
The damp boot is probably the upper tailgate seal. They can leak at the corners or at the hinge.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Re the towbar
rabbit17 Member Since: 22 May 2019 Location: midlands Posts: 11 ![]() ![]() ![]() |
Talk about a late reply |
ibb1 Member Since: 27 Sep 2013 Location: London Posts: 80 ![]() ![]() |
It looks like you’ve done all the stuff that needs doing-i.e. gearbox oil etc, from what I’ve heard the 8 speed isn’t nearly as troublesome as the 6 speed (I had a 6 speed fail in my old RRS too) and the 4.4 TDV8 is pretty good too.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Have you enabled the digital speedo with your iid ?
V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Welcome back |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
The genuine removable tow bar should fit perfectly with the design pack. The car we looked at before buying the one we have had the design pack and a detachable tow bar on it.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16329 ![]() ![]() ![]() |
The towing electrics don't come with an ECU on a 2011 so, there is a plug inside the spare wheel hole and the electrics simply plug into that...
