Home > My Range Rover > New owner from RRS to FFRR ...... |
Brunel Member Since: 10 Apr 2019 Location: Bristol Posts: 128 |
Nice. What ceramic coating did they use? |
24th Jun 2019 9:35am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
The damp boot is probably the upper tailgate seal. They can leak at the corners or at the hinge.
24th Jun 2019 9:56am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Re the towbar
24th Jun 2019 12:54pm |
rabbit17 Member Since: 22 May 2019 Location: midlands Posts: 11 |
Talk about a late reply
25th Jan 2020 3:07pm |
ibb1 Member Since: 27 Sep 2013 Location: London Posts: 80 |
It looks like you’ve done all the stuff that needs doing-i.e. gearbox oil etc, from what I’ve heard the 8 speed isn’t nearly as troublesome as the 6 speed (I had a 6 speed fail in my old RRS too) and the 4.4 TDV8 is pretty good too.
25th Jan 2020 3:51pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3785 |
Have you enabled the digital speedo with your iid ?
25th Jan 2020 4:15pm |
Welcome back
25th Jan 2020 4:50pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3137 |
The genuine removable tow bar should fit perfectly with the design pack. The car we looked at before buying the one we have had the design pack and a detachable tow bar on it.
27th Jan 2020 2:09pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
The towing electrics don't come with an ECU on a 2011 so, there is a plug inside the spare wheel hole and the electrics simply plug into that...
27th Jan 2020 4:36pm |
