Home > Technical (L322) > Rear air con always on
DrRob
Is it possible via a CCF change or otherwise to have rear air con set to off as default on start up?
I don’t need rear air con as default on start up Whistle
I’m forever switching it off Censored Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541900 25th Jan 2020 10:33pm
Poprivit
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Thought it was just me that did this, interested to find out the same.
Post #541925 26th Jan 2020 9:47am
DrRob
Me too Thumbs Up Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541927 26th Jan 2020 9:58am
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
I thought this was a mandatory requirement to keep the interior dried out due to the water-leaks-by-design feature Shocked "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #541929 26th Jan 2020 10:06am
i dont see it being a problem having it on....
any particular reason you want it switched off.. ... - .- -.
Post #541933 26th Jan 2020 11:03am
Weegie
His mother in law sits in the back? Rolling with laughter John
GAP iiD BT-Sold
Post #541934 26th Jan 2020 11:05am
Poprivit
Well in my case it just appears to be a waste when your the only one in the car! Rolling with laughter
Post #541935 26th Jan 2020 11:06am
DrRob
Same reason as above ☝️ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541965 26th Jan 2020 2:51pm
you could close the rear vents? ... - .- -.
Post #542015 26th Jan 2020 10:57pm
Poprivit
Yep, but that does feel like knowing the light is left on in a room but closing the door so you can’t see it! Shocked
Just a shame that with all those ecu’s she can’t remember what settings you made for this and defaults to on.
Post #542020 27th Jan 2020 8:17am
DrRob
This morning it was off when I started Confused Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #542023 27th Jan 2020 9:41am
GraemeS
Australia
I've found that after holding the button for a few seconds the rear air doesn't switch on automatically for several ignition cycles but then it reverts to being on. I haven't found any consistency in it staying off.
Post #542027 27th Jan 2020 10:26am
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Been wondering the same thing myself!!
I have an old iPhone in the compartment that has all my music on and sometimes it has a thermal shutdown due to the heat when I forget to turn it off. It would be good if the default was off.
Post #542047 27th Jan 2020 1:30pm
