Home > Technical (L322) > Rear air con always on |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Is it possible via a CCF change or otherwise to have rear air con set to off as default on start up?
25th Jan 2020 9:33pm |
Poprivit Member Since: 11 May 2014 Location: East Yorkshire Posts: 27 |
Thought it was just me that did this, interested to find out the same. |
26th Jan 2020 8:47am |
Me too Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jan 2020 8:58am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
i dont see it being a problem having it on....
26th Jan 2020 10:03am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
His mother in law sits in the back? John
26th Jan 2020 10:05am |
Well in my case it just appears to be a waste when your the only one in the car! |
26th Jan 2020 10:06am |
Same reason as above ☝️ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jan 2020 1:51pm |
you could close the rear vents? ... - .- -.
26th Jan 2020 9:57pm |
Yep, but that does feel like knowing the light is left on in a room but closing the door so you can’t see it!
27th Jan 2020 7:17am |
This morning it was off when I started Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Jan 2020 8:41am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
I've found that after holding the button for a few seconds the rear air doesn't switch on automatically for several ignition cycles but then it reverts to being on. I haven't found any consistency in it staying off. |
27th Jan 2020 9:26am |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 |
Been wondering the same thing myself!!
27th Jan 2020 12:30pm |
