Home > Maintenance & Mods (L405) > Replacing door Mirror ££££
Doodle
Mirror hit by approaching flatbed. Glass broken into three pieces. No damage to mirror shroud.
Phoned dealer parts and was informed the glass is very expensive to replace. I understood replacement would be £138.
The glass was fitted next day (no charge for fitting as it took about 5 minutes) and every mirror back light worked.
Invoice was for £188 plus VAT making £235.
Have spoken to parts Manager who insists this invoice is correctly priced.
Can someone confirm if this is correct L405 for one mirror glass for Autobigrapy ?
This is my local Land Rover Dealer who I have used for more than 20 years.
Seems a lot to me Sad
Post #541465 22nd Jan 2020 5:50pm
Dolphinboy
Have you looked on Fleabay or Amazon? I bought mine for £17 (for an L322) when the retail was nearly £90!! Shocked
this any good?
https://www.ebay.co.uk/itm/Right-driver-si...Sw70xZ4Hb9
Try Duckworths on here for a price.
Post #541469 22nd Jan 2020 6:11pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Mine was hit about a year ago by refuse truck and destroyed wing mirror, 2.5k from main dealer including new side window, so think yourself lucky.
Post #541515 22nd Jan 2020 9:39pm
CS
No experience of 405, but based on 322 prices that sounds about right. I had reversed a mirror into a tree Embarassed and the housing was broken but the glass survived intact. That cost about £600 I think and I was told it would have been £800 odd had they not been able to use the original glass bit.
If you want a third party check you could PM Dan@Duckworths for a price. Only Range Rovers since 1988
Post #541636 23rd Jan 2020 7:16pm
Big Boy R44ROV
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
Sounds about right. I paid over£190 for the n/s mirror. Because they are electrochromic it ramps the price up massively. Tony
You're always in the Censored ........it's just the depth that varies
2011 5.0 Autobiography Fuji White
2019 Audi Q2 in White
04 SL55AMG
Gone:
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
V8 Lightweight
Too many series to mention !
IID for L322
Post #541639 23rd Jan 2020 7:29pm
supershuttle
Rather than start a new thread today I kissed wing mirrors Shocked with a transit van (who didn't stop) so I need a new drivers side glass, everything else seems to have survived but as its an all singing and dancing, photo chromatic , heated and allows the blind stop stuff to show though I guess its expensive. The questions I have are; is there more than one part numbers (and if so which one do I need) and what's the cheapest source. Geoff
Post #541758 24th Jan 2020 4:37pm
have you tried sophie at duckworths....she'll probably ask for the vin so that you get the correct mirror.. ... - .- -.
Post #541764 24th Jan 2020 4:52pm
supershuttle
Thanks Birthday boy - I've popped Sophie the question Rolling with laughter Rolling with laughter Geoff
Post #541766 24th Jan 2020 5:13pm
when you get the replacement make sure you screw in on properly, you dont want it to fall off when you go down the road..
[birthday boy got a good memory]
Mr. Green ... - .- -.
Post #541771 24th Jan 2020 5:24pm
Laughing Laughing Laughing Bow down Whistle
Post #541772 24th Jan 2020 5:34pm
supershuttle
Indeed you have got a good memory, I still miss that car. I assume l405 and l454 (Sport?) are interchangeable. Geoff
Post #541774 24th Jan 2020 5:42pm
& D4 Facelift Thumbs Up
Post #541775 24th Jan 2020 5:53pm
supershuttle
Just bought a stick on one to be going on with. No reply yet from Sophie. There is a left hand one on Ebay for 100 quid so dependent on her reply and if the stick on one is any good I'll keep it and keep an eye out for a secondhand one. I realise I'll lose all the functionality but it was only 7 quid I suspect a new one might be significantly more expensive. Geoff
Post #542050 27th Jan 2020 1:04pm
supershuttle
Still no reply from Sophie - is this what I need ?
Item number eBay Item No. 264482674925 on Ebay Geoff
Post #542156 28th Jan 2020 3:17pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Yep - that should fit your AB. Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #542515 31st Jan 2020 9:33am
