Home > Maintenance & Mods (L405) > Replacing door Mirror ££££ |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
Mirror hit by approaching flatbed. Glass broken into three pieces. No damage to mirror shroud.
22nd Jan 2020 5:50pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3139 |
Have you looked on Fleabay or Amazon? I bought mine for £17 (for an L322) when the retail was nearly £90!!
22nd Jan 2020 6:11pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1374 |
No experience of 405, but based on 322 prices that sounds about right. I had reversed a mirror into a tree and the housing was broken but the glass survived intact. That cost about £600 I think and I was told it would have been £800 odd had they not been able to use the original glass bit.
23rd Jan 2020 7:16pm |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Ford Hill, Wirral. Not Merseyside Posts: 554 |
Sounds about right. I paid over£190 for the n/s mirror. Because they are electrochromic it ramps the price up massively. Tony
23rd Jan 2020 7:29pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
Rather than start a new thread today I kissed wing mirrors with a transit van (who didn't stop) so I need a new drivers side glass, everything else seems to have survived but as its an all singing and dancing, photo chromatic , heated and allows the blind stop stuff to show though I guess its expensive. The questions I have are; is there more than one part numbers (and if so which one do I need) and what's the cheapest source. Geoff |
24th Jan 2020 4:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
have you tried sophie at duckworths....she'll probably ask for the vin so that you get the correct mirror.. ... - .- -.
24th Jan 2020 4:52pm |
Thanks Birthday boy - I've popped Sophie the question Geoff |
24th Jan 2020 5:13pm |
when you get the replacement make sure you screw in on properly, you dont want it to fall off when you go down the road..
24th Jan 2020 5:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
24th Jan 2020 5:34pm |
Indeed you have got a good memory, I still miss that car. I assume l405 and l454 (Sport?) are interchangeable. Geoff |
24th Jan 2020 5:42pm |
& D4 Facelift |
24th Jan 2020 5:53pm |
Just bought a stick on one to be going on with. No reply yet from Sophie. There is a left hand one on Ebay for 100 quid so dependent on her reply and if the stick on one is any good I'll keep it and keep an eye out for a secondhand one. I realise I'll lose all the functionality but it was only 7 quid I suspect a new one might be significantly more expensive. Geoff |
27th Jan 2020 1:04pm |
Still no reply from Sophie - is this what I need ?
28th Jan 2020 3:17pm |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 |
Yep - that should fit your AB. Regards,
31st Jan 2020 9:33am |
