Home > Technical (L322) > Drivers door switches not working
GreaseMonkey
Hi, I have an issue with my RR 2004 L322 neither outer mirrors working, unable to open close any window from drivers side and central locking does not lock/unlock drivers door. All worked fine until I disconnected the battery for 30 mins and then reconnected to find these problems. Disembark switch working ok.
Anyone able to help please?
windows on passenger doors working fine from their respective switches.
Post #501314 12th Jan 2019 5:36pm
L322 Newbie
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Hi did you get a resolution to this issue? As after replacing the door handle cable today I now have the same issue, and was wondering what the cause was. Thanks Steve Steve
2007 L322 RR Autobiography Black
1999 X100 Jaguar XKR Black
2008 Smart 451
Post #538526 26th Dec 2019 1:41pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
I have this issue occasionally; always a blown fuse; sorry canโ€™t remember which number. "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #538550 26th Dec 2019 5:36pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Steve, yours is probably just that the connector is not seated properly
I and others have had the same issue after replacing the door handle Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #538576 27th Dec 2019 8:56am
L322 Newbie
Hi thanks, I have tried the fuses, will attempt to see if the connectors are seated correctly after the weekend,
Regards
Steve Steve
2008 Smart 451
Post #538665 28th Dec 2019 12:07am
Shambler
Having the same issues with mine, has anyone found a fix for the problem??
Post #538908 30th Dec 2019 1:57pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Fixed mine by:
disconnect battery
wait ten minutes
remove door card
pull out the three connectors to the door switch assembly
spray with WD40 contact cleaner, both the connectors and their respective sockets
leave for half hour to fully evaporate
reconnect everything
All good!
Post #541723 24th Jan 2020 2:00pm
Shambler
Mine was the BCM under the passenger seat, put passengers seat fully forward, disconnect battery wait 20 mins disconnect BCM, wait half hour re connect BCM re connect battery and hey presto all fine with drivers door switch pack ๐Ÿ‘๐Ÿป
Post #541725 24th Jan 2020 2:23pm
