![]() | Home > Technical (L322) > Drivers door switches not working |
L322 Newbie Member Since: 22 Mar 2017 Location: Boldon, Tyne & Wear, UK Posts: 26 ![]() ![]() ![]() |
Hi did you get a resolution to this issue? As after replacing the door handle cable today I now have the same issue, and was wondering what the cause was. Thanks Steve Steve
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 ![]() ![]() |
I have this issue occasionally; always a blown fuse; sorry canโt remember which number. "YYS" G4 FFRR
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Steve, yours is probably just that the connector is not seated properly
Hi thanks, I have tried the fuses, will attempt to see if the connectors are seated correctly after the weekend,
Shambler Member Since: 04 Nov 2017 Location: Gloucestershire Posts: 41 ![]() ![]() |
Having the same issues with mine, has anyone found a fix for the problem?? |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 ![]() ![]() ![]() |
Fixed mine by:
Mine was the BCM under the passenger seat, put passengers seat fully forward, disconnect battery wait 20 mins disconnect BCM, wait half hour re connect BCM re connect battery and hey presto all fine with drivers door switch pack ๐๐ป |
