![]() | Home > Technical (L322) > Beam pattern |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
The top picture is similar to my L322 (with HID's) in RHD mode.
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
Ah that’s interesting. I’ll take a look.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Up for UK use. Down for driving on the right of the road. Agree with Brian C. Mine are on continental use and the pattern is the same as second picture. John
Anyone offer any insight on how to find and move the bloomin lever ??
They are behind the caps at the side of the back of the light. If,as we susppect, they are set for continent then the levers are quite low. They aren't very sturdy and have a flat finger grip (for the want of a better description). Pull them straight up.
Ok someone answer me this lol.
I’m actually really confused now. As all the videos I watched and even in the manual which is not very clear it looks like the lever is different to the one I moved?
Sorry I misled you. The direction changed for later models and it became down for UK. It is a white lever.
Hey. Thank you so much for linking that thread. That’s out my mind at rest.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
I must look at mine I have one one way and one the other sort of a hitch pitch from my last France run |
Yes sir that's 100% the correct white adjuster and yes that's 100% the correct beam pattern you have selected... |
