Home > Technical (L322) > Beam pattern
dazza1983
Beam pattern
Hey chaps I have a query maybe you could help with...
do you have a distinct beam pattern from your xenon lights?
I learnt a lot about beam patterns from my last car but my range doesn’t seem to have one.
This is my wife’s mercedes Ml beam pattern it’s the same as my Bmw M3’s was. Very distinct.
And this is my rangy. It’s almost flat. Seems to be fine on the road I can see ok. Although sometimes I think they are slightly high or low I’m unsure. But the beam pattern seems very flat??
 Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #541628 23rd Jan 2020 6:36pm
Brian Considine
The top picture is similar to my L322 (with HID's) in RHD mode.
The other pictures are similar to the headlamps in LHD mode - you should find a couple of levers behind the covers that will change the beam pattern. 2003 Range Rover Vogue TD6
Post #541630 23rd Jan 2020 6:50pm
dazza1983
Ah that’s interesting. I’ll take a look.
Do you know should the lever be up or down? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #541634 23rd Jan 2020 7:05pm
Weegie
Up for UK use. Down for driving on the right of the road. Agree with Brian C. Mine are on continental use and the pattern is the same as second picture. John
GAP iiD BT
Post #541637 23rd Jan 2020 7:20pm
dazza1983
Anyone offer any insight on how to find and move the bloomin lever ??
I’m cold and struggling lol Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #541641 23rd Jan 2020 7:35pm
Weegie
They are behind the caps at the side of the back of the light. If,as we susppect, they are set for continent then the levers are quite low. They aren't very sturdy and have a flat finger grip (for the want of a better description). Pull them straight up.
HTH John
GAP iiD BT
Post #541644 23rd Jan 2020 7:41pm
dazza1983
Ok someone answer me this lol.
I found them they are big white levers and we’re the opposite to what I was looking. I actually had to push my levers down to get the correct beam pattern which is this one am I right???
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #541648 23rd Jan 2020 7:56pm
dazza1983
I’m actually really confused now. As all the videos I watched and even in the manual which is not very clear it looks like the lever is different to the one I moved?
I moved a white looking lever which looks like I now have the correct beam pattern. But is this the correct lever?
Sorry I suffer with OCD quite bad and things eat away at me unless I know I have done them correctly.
 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #541652 23rd Jan 2020 8:17pm
Weegie
Sorry I misled you. The direction changed for later models and it became down for UK. It is a white lever.
Page two on this thread has a picture which is quite clear. Same as you are showing.
https://www.fullfatrr.com/forum/topic2863.html?highlight= John
GAP iiD BT
Post #541656 23rd Jan 2020 8:41pm
dazza1983
Hey. Thank you so much for linking that thread. That’s out my mind at rest.
Something so trivial but it would eat away at me unless I knew what was the correct way etc. Proper ocd is horrible to live with lol.
But thanks again for taking the time to post that. Really really appreciate it. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #541659 23rd Jan 2020 9:00pm
Sandyt
I must look at mine I have one one way and one the other sort of a hitch pitch from my last France run
Post #541676 23rd Jan 2020 10:21pm
Yes sir that's 100% the correct white adjuster and yes that's 100% the correct beam pattern you have selected... Thumbs Up
Post #541695 24th Jan 2020 1:03am
