Home > Technical (L322) > iPhone integration
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Thanks Ajay, procedure slightly different but never the less - green and white shorted - ignition to pos 1 - count to 3 - unshort green and white and BT pairing started Thumbs Up
[Forgot the pairing code so had to 'extract' it from the ULF]
Best news is that once paired all the functions now work - deleting messages from vmail and most of all hanging up.
Guess the pairing process via navcoder never completed correctly.
Many thanks for your help.
Just have to get the BMW cradle wired up correctly now (don't suppose you have the correct pinouts for that to hand Whistle ) "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #54115 11th Mar 2011 4:41pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I cant remember which way round but I think the RR loom has an 18 pin female plug and the BMW Eject Box has an 18 pin female socket which means that you either need to change one or the other to give a male pin plug or a male pin socket Confused
Either way it will still be the same four wires already discussed and the eject box should have a red or maybe red/yellow wire to power any phone that uses a snap in cradle, a brown or black wire as a ground and the other two - well they will be for your pairing button so it wont matter which one goes to which Thumbs Up
That should sort it Cool
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #54165 11th Mar 2011 9:39pm
Deasy
Hi, is there in idiots guide to do this from the start? As in where to get bits from and how to do it? I have a 2002 vogue.
Any help would be nvery much appreciated
Cheers
Post #89069 26th Oct 2011 9:32pm
MrP
I think most of the info is in this thread - Gen 13ULF is the key part (BT phone unit from BMW - quite sort after on ebay but findable)then a bit of re-pining on the telephone loom (or get a new loom repined by some of the forum members). Have a search on the net and you will find various guides and video clips of the integration. It does work well (never got round to sorting out the cradle so mine does not charge the phone yet) with all the steering wheel buttons functioning.
-Simon "On first name terms with my local Dealer......now."
Post #89089 27th Oct 2011 9:43am
SteveMFr
Site Sponsor
Unfortunately L322.com went offline, but the info can be found at
http://web.archive.org/web/20100526171057/..._KITS.html
It doesn't get much better than that - if you don't feel comfortable re-pinning the connectors then you'll have to find an automotive electrician who can do it for you.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #89148 27th Oct 2011 3:20pm
