Home > Technical (L322) > L322 drivers window stuck down
smighall
England 2005 Range Rover Vogue SE Td6 Buckingham Blue
New switch from Ducky Dan (much cheaper than anywhere else i could find) has fixed mine Thumbs Up
Post #366888 13th Jan 2016 5:38pm
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Great news who is Ducky Dan? Cannot find a decent 2nd hand one.
Post #367115 14th Jan 2016 8:31pm
smighall
Duckworth's (site sponsor) and Dan is the guy who works there.
http://www.fullfatrr.com/forum/topic35579.html
Post #367125 14th Jan 2016 9:22pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Did fitting a new switch do the trick for you buddy?
Exact same issue here and if I can avoid dismantling the whole s*****g door then that would be a bonus Smile
Post #541209 20th Jan 2020 5:57pm
bleeperman
Yes new switch assy did the fix
Post #541225 20th Jan 2020 8:14pm
fenlander
Much appreciated thanks, I suspect a stuffed relay in the drivers window switch specifically the UP direction as I can hear a relay click in the DOWN direction but not the UP...
Will power the window motor manually to confirm everything else is good, once I find my old Maplins 12v Bench PSU Smile
Might have to dismantle the whole switch cluster and see if there's anything obvious to resolder (dry joint maybe?) or work out which relay is faulty... or buy a known-good one on fleabay for £100 or so if all else fails I guess.
What a deliberately dumb place to locate a switch cluster though, guaranteed to get wet and corroded over time!
Post #541231 20th Jan 2020 8:47pm
