Home > Technical (L322) > L322 Parcel shelf handle removal ?
GGDR
I want to remove my parcel shelf handle to refinish it.
There's a black cover underneath however some tugging and prodding with some trim removal tools didn't budge it.
Didn't want to break it so thought I'd better ask around...
Anyone done this?
 Cheers, Greg
Post #541115 19th Jan 2020 11:12pm
DrRob
Probably glued or bonded very tightly Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541137 20th Jan 2020 7:48am
its me
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Its no glued or bonded,just clips on. Prise around the edges of the back part and you will find that it will spring off. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion
Post #541138 20th Jan 2020 8:00am
GGDR
Big thanks!
. Cheers, Greg
Post #541142 20th Jan 2020 9:04am
WB
Ooh what's your plan for refinishing? are you doing anything with the shelf too or just the handle?
Post #542164 28th Jan 2020 3:40pm
andyrosehome
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Cairns Blue
Hi Folks. I know this thread is a few years old now but it is the only info I could find on removing the cargo shelf handle so I figured that it was worth posting my experience to help anyone thinking of refinishing their own handle.
The handle is made in 2 parts i.e. the black lower part and the painted upper part which gets damaged and looks scruffy.
If you place the shelf on a clean work surface, upside-down so that you can see the black part of the handle. Then using a large flat blade screwdriver, place the blade under the edge of the handle that runs parallel to the box section to lift the black part of the handle away from the shelf. It does take quite a bit of force and a plastic trim tool can help you to get a better bite once it starts to pop off. Then gradually work your way around the 8 retaining clips. I did break one clip as you will see in the photos but it went back together just fine with 7 clips.
I had planned to repaint my handle but I cleaned the old paint off with acetone and found that the base plastic body colour was a close enough colour for me so I just wet sanded it and polished it with a mop and cutting compound. This makes it less likely to get scratched and chipped. Hope this helps. See photos if they upload.
Post #699314 2nd Sep 2024 11:39am
