![]() | Home > My Range Rover > Thinking of L322 5.0 SC |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Or a nicely looked after 4.4 tdv8 |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
I went from a 3.6 TDV8 to a 5.0SC and while both had their merits I'm a big fan of the 5.0. Apart from the fuel consumption it's just about my ideal car.
Yossarian Member Since: 07 Mar 2011 Location: Wales Posts: 66 ![]() ![]() ![]() |
Thanks for the guidance, much appreciated. There seems to be a few for sale on the market but i'd have much rather found one from here knowing it had been looked after. Does the timing chain etc have to be replaced? I know what can happen if its not done, but are all engines afflicted with the same issue?
Yes the timing chain will need doing at some point as will the supercharger coupler. You could always risk it if you're not planning to keep the car for long but it's potentially a lot of the engine to replace if it goes and the cost of that would probably write off the car.
