Home > Maintenance & Mods (L322) > EGR valve was very clean when removed |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
Could the EGR have been replaced in the past & everything cleaned up at the same time ? Paul,
12th Jan 2020 11:48am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
I doubt it, I’ve owned my TD6 for 10 years now and haven’t had it done, bought her on approx 80k and now on 116k
12th Jan 2020 7:49pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I wonder if the valve is closed to the recirculating pipe and thus no recirculated gases have ever flowed through the egr, ie it has never actually worked properly at all.
12th Jan 2020 9:02pm |
Ahhhh, i was wondering the same nicedayforit
13th Jan 2020 10:43am |
I would just leave the blanking plate on but keep the egr valve just in case you ever need it if the mot regulations change to allow mot testers to check if it is fitted. Wouldn't surprise me if this happened, even if you had to present your car with the necessary covers removed to allow inspection.
13th Jan 2020 4:04pm |
