![]() | Home > Range Rover Classic > sd1 and RR engine |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Talking of which, does anyone recognise this New (very) Old Stock badge? |
Well noticed about the SD1 position |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
I thought the Triumph V8 was different being OHC ? 2003 Range Rover Vogue TD6 |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 555 ![]() ![]() |
The Triumph Stags were indeed different....and completely useless,hence the popular conversion to the Rover V8.
A friend of mine who was also a good motor engineer had one & it was always having overheating issues.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
I think the Stags V8 was essentially 2 Dolomite engines joined together. Sounds nice though.
Indeed they were and along with cooling issues that have already been mentioned, stretchy cam chains could be an issue as well. |
Amazing! |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 467 ![]() ![]() |
[quote="Big Boy R44ROV"]
The 3.9 and the 4.0 share exactly same number of cubic centimetres, but there's one very fundamental difference between the two. The 4.0 has larger cross bolted main bearings and is therefore a much stronger engine. This is the one to have if you're going for more power (over the non-cross bolted and smaller main's of the 3.5's and 3.9's) Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
