Home > Range Rover Classic > sd1 and RR engine
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Talking of which, does anyone recognise this New (very) Old Stock badge? Mr. Green
Post #540095 10th Jan 2020 9:55pm
Big Boy R44ROV
Straight from an SD1 brilliant badges. And in the correct position too Thumbs Up Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #540099 10th Jan 2020 10:16pm
Red Merle
Well noticed about the SD1 position Thumbs Up
Post #540148 11th Jan 2020 10:04am
Brian Considine
I thought the Triumph V8 was different being OHC ? 2003 Range Rover Vogue TD6
Post #540151 11th Jan 2020 10:24am
Big Boy R44ROV
The Triumph Stags were indeed different....and completely useless,hence the popular conversion to the Rover V8.
I believe they suffered from overheating and cooling issues from poor castings. The TR8 was the Rover 3.5V8 unit. Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #540166 11th Jan 2020 12:22pm
Brian Considine
A friend of mine who was also a good motor engineer had one & it was always having overheating issues.
Thanks for confirming that it was different.
Having said that when running well it sounded awesome. 2003 Range Rover Vogue TD6
Post #540168 11th Jan 2020 1:01pm
mjdronfield
I think the Stags V8 was essentially 2 Dolomite engines joined together. Sounds nice though.
Previous cars :
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #540169 11th Jan 2020 1:27pm
Red Merle
Indeed they were and along with cooling issues that have already been mentioned, stretchy cam chains could be an issue as well.
Post #540213 11th Jan 2020 4:42pm
Big Boy R44ROV
This is brilliant. And probably more powerful than the Rover V8!
Hipe it works!! Tony
2014 SL63 AMG White
Gone:
00 TD5 90 County
97 3.9ES Disco
Post #540250 11th Jan 2020 9:37pm
Red Merle
Amazing! Thumbs Up
Post #540269 11th Jan 2020 11:59pm
D3Jon
[quote="Big Boy R44ROV"]
ilard wrote:
The 4.0 was essentially the 3.9, but badged as a 4.0 because Jeep had the Cherokee 4.0, and it couldn't be seen to be smaller !.
But in essence it's still the same lump.
The 3.9 and the 4.0 share exactly same number of cubic centimetres, but there's one very fundamental difference between the two. The 4.0 has larger cross bolted main bearings and is therefore a much stronger engine. This is the one to have if you're going for more power (over the non-cross bolted and smaller main's of the 3.5's and 3.9's)
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #570343 19th Oct 2020 8:01pm
