Home > Technical (L322) > tail lights
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
you are more than welcome to come see.thanks for trying i do need the help .i think i am going to beat it with a large stick Wink Wink
Post #540130 11th Jan 2020 12:28am
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I don’t need to see 😀😀 there’s clearly something wrong with yours . However the std configuration is as described , bottom bulb is fog or sidelight dependent on signal from LCM , upper bulb is sidelight only - comes on when switch is at position 1 or 2 . The 2nd filament in middle bulb is not used - I checked on mine this morning when changing a number plate light bulb -
If yours has sidelight and fog light via the middle bulb , your wiring is modified or the LCM is screwed 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #540186 11th Jan 2020 2:11pm
