Home > Technical (L322) > Electric brake controller
Tinman
A question to you guys in Australia I have seen a post on here some time back about the wiring of an electric brake controller?
I am not sure if it was for a pre-2010 module as I have 2011 If someone could point me to the post they put up it will be a great help as looking the take my car to Australis in a few months and would like to get things done before I get there.
Post #540147 11th Jan 2020 8:59am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Run a live feed direct from the battery to the unit with a 20a self resetting fuse in line
Run a thickish 2 core cable from the unit to rear of the car. Use one of the cores as the trigger from the brake light and the other for the actual braking signal to the trailer.
I use Tekonsha brake controllers, mine is located just above the OBD port on the dash. Easy.
Your UK trailer plug will need to be rewired as its not the same over here. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #540187 11th Jan 2020 2:16pm
Tinman
Thanks for the reply Wayneg seems simple enough I will pick up a flat socket when the car is over there Thumbs Up
Post #540214 11th Jan 2020 3:46pm
