Home > Technical (L322) > tail lights
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
tail lights
has anybody had problems with their tail lights, mine are not working but fog, side ,brake and indicators are Confused
Post #540089 10th Jan 2020 8:22pm
so they are working then???? ... - .- -.
Post #540100 10th Jan 2020 9:21pm
Harlin
no the tail light is not ,the middle bulb , i can turn on side lights ,but if i turn on main beam nothing
Post #540104 10th Jan 2020 9:37pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
What are you expecting to be different at the rear on “main” beam ? 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #540105 10th Jan 2020 9:42pm
have you standard SC lights ?
Post #540106 10th Jan 2020 9:43pm
Harlin
yes i do .
Post #540107 10th Jan 2020 9:45pm
Harlin
when you turn your lights on
the back ones are meant to come on too yes
Post #540108 10th Jan 2020 9:48pm
m@ttsFF
Yeah , of course , but they come on with the sidelights .. not main beam
If no tail lights at all , start with fuses I guess 4.2 SC - sold , now bought back
Post #540111 10th Jan 2020 10:02pm
Harlin
been through the book twice and can not find a fuse for the rear lights ,i tried no 4,and that one is good ,may be there is one i am missing or its a relay
Post #540112 10th Jan 2020 10:09pm
so switch on side, the front sides and tails come on?
when switch on headlight dip the front sides and rear tails go off? ... - .- -.
Post #540113 10th Jan 2020 10:12pm
Harlin
on the dash ,first click of lights and the side lights front and back come on ,,second click and the main beam comes on the front (not high beam)but not lights come on on the back .hope that makes sense
Post #540114 10th Jan 2020 10:19pm
what i said then...
it could be the switch or the LCM , just a guess.. ... - .- -.
Post #540115 10th Jan 2020 10:23pm
m@ttsFF
tail lights come on with the sidelights up front ... switching to dipped headlights doesn’t change anything at the rear ? 4.2 SC - sold , now bought back
Post #540117 10th Jan 2020 10:24pm
Harlin
yes it dose the bottom bulb has one filament in for the side light and the middle bulb has two filaments in , one for the tail lights and one for the fog light .the filament for the tail light dose not come on at all
Post #540118 10th Jan 2020 10:30pm
m@ttsFF
The bottom bulb is fog and tail light ... the upper just tail , 2nd filament is unused , so maybe a bulb issue ?
Post #540125 10th Jan 2020 11:16pm
