![]() | Home > Technical (L322) > Crankshaft Position Sensor (CKP) |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
Hello,
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
Thank you for the info. I'll take a look as soon as the ground dries up a bit. Is it possible without removing the undertays or do they all have to come off for access? There is a difference between knowing your sh!t and knowing you're sh!t
trays will def need to come off im afraid.
Rear tray only removed. Took less than 5 mins to swap the sensors with the vehicle in off road mode and on a set of ramps Nice easy job and much quicker than I thought.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Aside from eml what symptoms did you get? Rough idle? Current stable:
What faults did you have to make you change this?
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
Hi Dan, I had a Ford Explorer that had intermittent starting and it turned out to be the electrical plug onto the crank sensor was dirty/corroded. A quick clean up of the plug cured it completely. Worth a try? |
If it’s not silly money I will buy a sensor too and clean it all and fit - just trying to get hold of Rob at duckworths now Current stable:
