Home > In Car Electronics (L322) > lights
Harlin
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
lights
should the green back light and red park light on the gear shifter stay on after the doors are locked , mine stay on all the time
Post #539853 8th Jan 2020 8:24pm
Harlin
36 people and nobody has gone outside to have a look Laughing
Post #539881 8th Jan 2020 11:10pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Dont think so , why would they Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #539882 8th Jan 2020 11:36pm
Harlin
why would they go outside or stay on Confused
Post #539886 9th Jan 2020 12:04am
dolph34
Why would they stay on , ny 2007 one didnt Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #539887 9th Jan 2020 12:08am
Harlin
i am having a problem with battery drain was just asking because i have not noticed them on before
Post #539888 9th Jan 2020 12:12am
dolph34
The lights staying on would definitely not help. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #539889 9th Jan 2020 12:13am
Harlin
just got to work out how to turn them off then Wink
Post #539890 9th Jan 2020 12:15am
dolph34
Hopefully one of the experts on here will help Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #539891 9th Jan 2020 12:19am
Harlin
thats what i was hoping for Very Happy
Post #539892 9th Jan 2020 12:22am
ctjfb
I seem to recall from several other threads on voltage drain that these lights going out (eventually) is one of the things to check when seeing if the various ECUs are going into sleep mode correctly ...
Chris Chris
2012 TDV8 4.4 Westminster
Post #539896 9th Jan 2020 2:29am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
The background lights on the shifter must turn off after about 20min when the car goes to sleep mode regardless if it is locked or unlocked. Smile RR HSE 4.4 2006 LPG
Post #539897 9th Jan 2020 7:34am
supershuttle
I’m doing this from memory as I now have a 405 but the Park light was not on all the time on my previous cars. I would have noticed it while driving- particularly at night. I don’t know about parked I just locked and walked away.😀 Geoff
Post #539899 9th Jan 2020 9:26am
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Other than the red flashing LED on the dash I'd have thought there should be no lights on in the car once its locked & shut down after 20 minutes or so.
Sounds like an ecu isn't shutting down.
Have you had any faults read / investigated?
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #539907 9th Jan 2020 10:26am
Brian Considine
Patience is a virtue (& something you need when running a FFRR)
They do stay on for a while & then go off as part of the "go to sleep" process. 2003 Range Rover Vogue TD6
Post #539908 9th Jan 2020 10:40am
