Home > Technical (L405) > windscreen replacement
Do you have glass cover Stan? If the screen is damaged/chipped badly? Why not have the screen replaced then you can be sure its not the glass at fault Thumbs Up
Post #539776 7th Jan 2020 11:11pm
i do have cover on my insurance but i dont really want to have the hassle of having it done.. ... - .- -.
Post #539793 8th Jan 2020 8:30am
Bill
If it’s the windscreen busted it’s the insurance company and doesn’t count as a claim.
If u still have warranty you can ask and might get range Rover badged glass.
Whooops. Just realised there was a page two and Craig had answered . As an aside never found any agro with the insurance company & I keep replacing the glass Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #539835 8th Jan 2020 5:05pm
supershuttle
I had one replaced on my last FF, done by Autoglass under insurance (IIIRC I had to pay seventy quid) I was very pleased it wasn't marked Land Rover but was Pilkington and they replaced all the clips for the surrounds. Geoff
Post #539854 8th Jan 2020 8:41pm
Triarii
United Kingdom 2017 Range Rover Autobiography SDV8 Corris Grey
Took GS Bristol 15 days to replace my windscreen - failed elements on the driver side. Couldn't get the parts or the fitter they said. 17 MY Corris Grey 4.4 VAB
Silver MB R231 SL350
Post #540309 12th Jan 2020 2:51pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
There are two connection per A pillar
I had mine replaced by National Windscreen and they managed to connect one of the lower wires to the wrong cable - hence that side did not work.
The cables they connect to are thick and around 2 to 3mm diameters not the thin ones, beware they are right next to each other.
On the L405 there are also two 40 amp fuses in the engine fuse box.
Hope this helps
3.0 Autobiography 14M5
Post #540317 12th Jan 2020 4:43pm
good info , thank you.....now i need to get off my bum and have a look Mr. Green ... - .- -.
Post #540318 12th Jan 2020 4:47pm
update...from reading other posts re the plugs/wires being incorrectly connected [windscreen installers???]
i removed the pillar trim and found a thin wire/plug connected and a thick wire/plug loose..
checked with a multimeter and when the front screen was on there was voltage from the thick plug/wire and nothing from the thin one.
the wiring diagram confirmed the wrong plug was connected so i change the two plugs over and it looks like it all works...waiting for frost now to confirm.. ... - .- -.
Post #541732 24th Jan 2020 3:31pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
charlie croker mk2 wrote:
The wiring for the 2 sides of the heated front screen is from a junction box in the engine bay .The relay is common to both sides and after that the 12 v feed splits into 2 , each of which is protected by a 40amp fuse . I suppose you could use a test meter in these points ( with the engine running ) . If there is no 12V at the relay then its down to the switch itself or the body control module . If there is 12v at the fuses then its the screen or more likely the connection to it . If you have a diagnostic then you will be able to see the BCM go live ?
The passenger side of my L405 windscreen does not demist and I have been trying to find the fuses after reading that there are two (one for each side). Nothing on my vehicle tells me where they are or even if they exist. Have I imagined it? Guidance please. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #686662 28th Feb 2024 11:03am
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
I've downloaded the wiki. It doesn't mention fuse box locations on l405. 2013 SDV8 4.4 SE Luxor.
1960 Series 2 88 inch diesel.
1955 Series 1 86 inch petrol.
Post #706863 14th Dec 2024 3:22pm
Some of the individual fuses changed for later cars, but I think the fuse boxes are in the same locations.
Post #706868 14th Dec 2024 6:19pm
Another post that may help - https://www.fullfatrr.com/forum/post687010.html
Post #706869 14th Dec 2024 6:23pm
