Home > Maintenance & Mods (L322) > Rear wiper and washer not working
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
I've had a search of the wiki and some posts but I've not found the answer.
My rear wiper is hanging vertically and does not respond/move. Any suggestions on what to try first? Is this a common fault?
It's a TDV8 L322 56 plate. Thanks guys.
Post #539334 3rd Jan 2020 11:01pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Well if you haven't checked the fuse, try that first.
If the fuse is ok, switch the rear wiper on and assist the wiper movement with your hand. The wash can leak in to the motor and the gears can get knackered.
If that doesn't get it going, you're probably looking at a new motor. They're quite a common failure.
Post #539338 3rd Jan 2020 11:44pm
stuartj9
Thanks for the reply. From my reading, am I correct in assuming there are 2 fuses? Do you know which ones? Looks like my first port of call is Amazon for some fuses or, could I whip out a similar fuse to try it from something else?
I've read about cleaning the motor up and fixing the leak if there is one. Is this worth a go?
Post #539339 4th Jan 2020 12:05am
Brian Considine
No wonder small shops & suppliers are going out of business if people depend on amazon for stuff like fuses.
Even the minimart style Shell/BP/Texaco filling stations stock fuses. 2003 Range Rover Vogue TD6
Post #539355 4th Jan 2020 9:35am
stuartj9
Brian, I didn't know they sell them there as I've never seen them. I'll go to my local one now.
Post #539360 4th Jan 2020 9:56am
Brian Considine
Hi Stuart,
I was being a little tongue in cheek but most filling stations have a small section (usually rucked into a corner) that sells a few bulbs, fuses & other bits.
Brian 2003 Range Rover Vogue TD6
Post #539364 4th Jan 2020 11:33am
gilesharrison
I've not tried rebuilding the motor but I know people have done it successfully.
Can't remember which fuses are involved. You don't necessarily need replacement fuses, they might be fine. Check which fuses are responsible for the wiper, pull them out, inspect the wire and make sure it I see continuous/ not burned out.
Post #539388 4th Jan 2020 4:53pm
stuartj9
Thank you all. I think I will go down the route of cleaning the motor and crossing my fingers. Grateful for any help off anyone who's managed to do this.
With the wiper hanging horizontal, I'm thinking it might need a new gear if it's been worn out but I've not checked it yet.
Post #539398 4th Jan 2020 6:27pm
stuartj9
UPDATE - so the jet is letting water out and I can hear the wiper motor but it's not moving. Should I remove and take the motor apart to see what's going on. Surely this is a good sign.
Post #539491 5th Jan 2020 4:22pm
Dolphinboy
I bet your motor cog has stripped or unseated itself. It’s dead easy to open the motor and clean/have a look/repair. Thumbs Up
Post #539499 5th Jan 2020 5:04pm
stuartj9
Cheers. I will dismantle and take a look. I've seen a replacement gear/cog if I need one.
Post #539503 5th Jan 2020 5:23pm
roblane65
had this problem a few months ago myself you' ll probably find a small damaged area of three or four teeth on the cog.
they are available on flea bay for a few quid but it can turn into a pain in the arse. So a word of warning.
the cogs also fit some minis and beemers.
make sure you get one with the magnet fitted. when I got the first one no magnet so swap them ! no chance
round magnet in original and square holder in new cog, So I got another with magnet Big Cry all fitted up and wiper arm was stopping where ever it wanted ,no intermittent an no washer Big Cry got a mate ( electrical wizard ) to check it out
and all the mischief was down to the fact what ever lovely person had fitted the magnet in the sweat shop it came from was the wrong way round magnets are poled ,and the hall effect pickup was not seeing the magnet and stopping every thing working correctly . Take some pics when you pull the cover to make sure the mechanism goes back together the same. and good luck. Range rover 4.2 SC 06MY.
Post #539536 5th Jan 2020 7:34pm
