Home > Maintenance & Mods (L322) > Rear wiper and washer not working |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 |
Well if you haven't checked the fuse, try that first.
3rd Jan 2020 11:44pm |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 |
Thanks for the reply. From my reading, am I correct in assuming there are 2 fuses? Do you know which ones? Looks like my first port of call is Amazon for some fuses or, could I whip out a similar fuse to try it from something else?
4th Jan 2020 12:05am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
No wonder small shops & suppliers are going out of business if people depend on amazon for stuff like fuses.
4th Jan 2020 9:35am |
Brian, I didn't know they sell them there as I've never seen them. I'll go to my local one now. |
4th Jan 2020 9:56am |
Hi Stuart,
4th Jan 2020 11:33am |
I've not tried rebuilding the motor but I know people have done it successfully.
4th Jan 2020 4:53pm |
Thank you all. I think I will go down the route of cleaning the motor and crossing my fingers. Grateful for any help off anyone who's managed to do this.
4th Jan 2020 6:27pm |
UPDATE - so the jet is letting water out and I can hear the wiper motor but it's not moving. Should I remove and take the motor apart to see what's going on. Surely this is a good sign. |
5th Jan 2020 4:22pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3162 |
I bet your motor cog has stripped or unseated itself. It’s dead easy to open the motor and clean/have a look/repair. |
5th Jan 2020 5:04pm |
Cheers. I will dismantle and take a look. I've seen a replacement gear/cog if I need one. |
5th Jan 2020 5:23pm |
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 |
had this problem a few months ago myself you' ll probably find a small damaged area of three or four teeth on the cog.
5th Jan 2020 7:34pm |
