Home > Maintenance & Mods (L405) > 6 pot brake pad sensors
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Just managed to pick up a whole set of brembo 6 pot callipers and discs. I know a forum member has recently done this conversion from the standard calipers. I haven’t had a good look but I can see where I brought them from has just cut the brake pipes and sensors. So although the pads are pretty good I guess I’ve got to buy new sensors? Or can I use the sensors from my old pads? I know some just clip into the pads.
Post #539527 5th Jan 2020 6:44pm
Felstmiester
Ignore that question guys. All standard hoses and sensors can be re used. Good old powerful uk.
Post #539561 5th Jan 2020 10:49pm
But only if the sensors come out of the old pads which they more often than not wont! Plus im pretty sure the sensor wires are a different length in the 6 pots sir... Thumbs Up
Post #539566 6th Jan 2020 12:00am
Felstmiester
Be worth getting some new ones in before starting the swap then. Cheers Craig.
Post #539572 6th Jan 2020 7:35am
Felstmiester
Any pointers on what pads are ok? Are pattern pads ok? Always found they create so much more brake dust
Post #539782 7th Jan 2020 10:54pm
Ive not found any non genuine pads that work personally but, some on here like EBC... Ive tried EBC in my D2 pickup and didn't rate them... Rolling Eyes Thumbs Up
Post #539783 7th Jan 2020 11:35pm
Felstmiester
Got back from work at 12 today so fitted fronts. Got new pads and sensor but managed to use the original sensor. Didn’t have time to tackle the rears but did have a quick look. The rear callipers look exactly the same?? Apart from the new ones I’ve got being red are they the same?
Post #539852 8th Jan 2020 7:21pm
It wouldn’t surprise me if they were the same...
Rears will need a diagnostic computer to put into maintenance mode too... Thumbs Up
Post #539855 8th Jan 2020 7:41pm
Felstmiester
Ok. Sort of part of the reason I thought twice about attempting this today. I noticed they have some kind of motor on the back. I’m sounding an absolute rookie now. But I thought it might be something like a new design for electronic handbrake? Or are the shoes still inboard like the older lr’s
Post #539865 8th Jan 2020 8:26pm
Electric handbrake it is sir Thumbs Up
Post #539895 9th Jan 2020 12:31am
Fifth Horseman
Scotland 2018 Range Rover Vogue SE SDV8 Carpathian Grey
Park Brake Service mode can be entered without diagnostic kit, instructions in second post in this thread:
https://www.fullfatrr.com/forum/topic53022.html
Post #539948 9th Jan 2020 2:36pm
Thats all well & good Horseman, but it doesn't tell you the procedure to bleed the rear callipers after replacing them! And im not sure id want to do the whole job on my driveway without a diagnostic computer to hand "incase i would need to reset something or programme/calibrate the replacement rear callipers?
Post #540008 9th Jan 2020 11:46pm
