![]() | Home > Technical (L322) > Suspension fault / Adaptive Dynamic Fault |
Smiggy Member Since: 11 Mar 2019 Location: Devon Posts: 21 ![]() ![]() ![]() |
C1A00-1D can be caused by rear air suspension control unit.
Mikem Member Since: 13 Jan 2019 Location: Kent Posts: 48 ![]() ![]() ![]() |
I had the active dynamic fault come replaced the front cables on the front strut tops but the fault was still there so could not access any of the special programs eventually the fault was found out to be the rear ride height sensor had gone had a new one fitted job done |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 ![]() ![]() ![]() |
Those are all invalid data received from modules. Sounds more like a can bus fault to me but would check modules first, as the first fault might well be a clue though. Circuit current out of range could be a short, poor connection, or one of the modules drawing too much. Too many toys, not enough time
Looks like I have solved the issue.
