![]() | Home > Technical (L322) > Help with a Part Number please! |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1810 ![]() ![]() |
Not available as a separate part. You need to buy the whole manifold assembly... |
madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49 ![]() ![]() |
Really?! It’s just a three inch long plastic nipple!
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Dependent upon how urgent the supply of the part is, if you are not in too much of a rush Aliexpress is worth a search. The part you need only comes from the MD as a whole unit assembly and is expensive, ISTR in excess of £59.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
What happened to your turbo exactly?
Tom Member Since: 23 Feb 2019 Location: Midlands Posts: 9 ![]() ![]() |
Just to add to this, I broke the same part. It joins a 10mm ID hose (9.89mm) to an 8mm ID hose. There's a fitting on Amazon that's metal that leaks, but I've found the right connector on eBay for £5.69 delivered. Be careful, lots of listings are from China or Hong Kong: https://www.ebay.co.uk/itm/8mm-10mm-Car-Mo...4550246853 |
