Home > Technical (L322) > Part code for turbo intake seal
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
2007 TDV8 RH Turbo.
Trying to get a rubber seal - the one that sits between the turbo and the incoming air pipe.
The numpo who installed it before has crumpled it beyond belief.
I can only find a part code for the entire incoming air pipe and the seal which seems excessive when its only the seal that's had it.
Does anyone know if the seals available and if so what their part code might be.
Thanks in advance.
Post #605056 28th Aug 2021 2:53pm
RJPotts
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Microcat: https://allbrit.de/select.cfm?CAR=TLJ&SPRACHE=EN
Post #605058 28th Aug 2021 3:16pm
