Home > Technical (L322) > L322 Transfer case motor |
uteman Member Since: 23 May 2012 Location: Newport, Victoria Posts: 11 |
Speed change motor sometimes stuck in Neutral so when it was in high range i removed motor to dismantle and inspect internally.
31st Dec 2019 6:57pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Remove the housing/cover from the armature on the shift motor, fit this motor back on, and manually wind the transfer box (spinning the armature by hand) back to high speed .
31st Dec 2019 8:00pm |
Thanks for your information.
31st Dec 2019 9:02pm |
To be honest, I can't remember which way to spin it, but wind until it won't go any further then put in the key and see where you are. I remember a distinctive clonk or end point. .
31st Dec 2019 9:40pm |
You sir are a gem!
1st Jan 2020 12:43am |
