![]() | Home > In Car Electronics (L322) > Headunit Upgrade on 2006-2010 - Work in progress |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Hi all,
2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Good to see options coming for 2006+ FF’s.
Yea you do didn’t bother me too much terrain response wheel still works but nothing on screen Current stable:
TDSIX Member Since: 19 Feb 2017 Location: Stirlingshire Posts: 210 ![]() ![]() ![]() |
This looks excellent. I'm just looking into option to upgrade the clunky system in my '07 with rear screens. Are there any plug and play options that'll work with current screen and buttons on the steering wheel etc.? 2010 FF 4.4 TDV8 Vogue - Gone
Morning - this works fine with the steering wheel for volume / skip and voice button. you lose the 4x4stuff obviously. What screen are you referring to?
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi mate which one is the slimline version you mention do you have a link please cheers. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Hi there it’s this I have not tried it and you need to check it dit’s but from the picture it looks ok...
Update...
tveitan Member Since: 10 Dec 2016 Location: Norway Posts: 47 ![]() ![]() ![]() |
Hi! screen looks really good in your car. I have just connected mine in the boot to see if everything works, and i'm quite pleased with the unit. looking forward to getting it installed properly.
I bought one off of amazon and used the cigar lighter to power it as on the 06+ it is ignition live - all working well on that front.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1464 ![]() ![]() ![]() |
Thats a smart looking option |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
Hi Dan
I will have to find a different power source since mine is 2002. Do you have a link to the hub? Does the hub run on 12V or do you have a converter? That's annoying... Hopefully there is a workaround for it. EDIT: Just thought of something, according to iBus installation guide you cannot use a usb hub, otherwise the app won't recognize it. Have you tried the ibus connected directly to one of the usb ports on the unit? 2002 Range Rover Td6 |
interesting - i will have to see if i can make it reach to try it
