![]() | Home > In Car Electronics (L322) > Headunit Upgrade on 2006-2010 - Work in progress |
vnitos Member Since: 18 Nov 2010 Location: pretoria Posts: 390 ![]() ![]() ![]() |
@Dan, are you still happy with the head unit |
Hi Dan
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Still the same need to do the Dab , new issue
abalanos Member Since: 12 Oct 2018 Location: Provence Posts: 11 ![]() ![]() |
Hi Dan,
So that AliExpress one is basically the same as the erisin style 10.25 units you can pick ups for around £220 and it has the rca to most adapter.
Thanks for the info Dan really helpful.
The other reason for the long fibre cable is you need to leave all the original units in the boot if any one of those fails it will take out the most ring so for extra security and so I could remove them the dedicated cable was the way for me Current stable:
Ok, I see now, makes very good sense.
Correct if you can get a slightly longer one it is better as it’s very tight at that length Current stable:
Yes, I meant to say 5m extension...
5m is enough its. little tight so you may need to spend some time routing it in different ways for optimal routing but it will work. Current stable:
Right update on this - since the use of the dac after the built in audio failed the telephone quality was very poor and the fm radio would not work.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Is this one a simple Plug and play for early L322s (2002/2004) since it is for BMWs, please? or does one need adaptors?
if you have an hse a monkey could fit it if its a vogue you will need to route a 5 m extension cable from the entertainment corner of the boot up to the screen.
