Home > Technical (L322) > Fuel sender 2 and rear passenger window
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Got a few problems first the fuel sender 2 coming up on reader three gauge dropped to empty and the light is on also the range has just got three lines I recently replaced it the original one but I used one off eBay 🙈 it’s been good for 6 months the original one was not sending fuel to the other side of the tank Could I have just swapped the smaller side or is it the main larger side that does this ?? Also the drivers rear window has stopped working all together now before it was lowering its self so I turned the rears off with the switch but when I turn it back on now there is nothing on drivers side the passenger one is working fine.please if anybody has any idea HELP please
Post #536768 9th Dec 2019 12:13pm
rjff
Andy,
You've had the senders out so know your way around the tank area.
There are a few threads about this on here. Can be caused by the connectors in the tank beginning to fail and rewiring with a mod that entails crimps being fitted in place of the connectors.
https://www.fullfatrr.com/forum/topic47521...=fuel+tank
https://www.fullfatrr.com/forum/topic46574-15.html
The Technical Service Bulletin covering this is here,
https://www.fullfatrr.com/gallery/albums/u...8-6294.pdf
Hope this helps Cheers
Richard
Gap IIDBT
Post #536791 9th Dec 2019 2:55pm
andyfid
Excellent cheers I will take a look and see if that works at weekend cheers
Post #536815 9th Dec 2019 5:12pm
Bingo_123
What's the difference between a tsb and a recall?
Facing similar symptoms, so thinking of getting it fixed the proper way.
Post #536833 9th Dec 2019 8:37pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
A recall relates to an issue endangering life? A TSB is just a way for the manufacturer to communicate common issues and their resolution to the field in a structured way. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #536837 9th Dec 2019 8:53pm
rjff
Andy
On the window, there are one or two threads about the drivers door switch panel contacts on the connectors becoming corroded. IIRC the cause could be ingress of water when the drivers window is open, the runoff from the windscreen in rain and from the wipers is perfectly channeled round the A pillar and down onto the switch unit. Might be worth a look on that and the rear door switches and connectors, but it does mean door cards off I think.
Use a trim removal tool set if you can, the fasteners are easily broken with a screwdriver. For the sake of a few £s on ebay or Amazon it's a no brainer. Cheers
Richard
Gap IIDBT
Post #536855 9th Dec 2019 10:02pm
andyfid
Great even more water problems I bet,I will take off both door cards and get some new clips because my luck is they will brake off I have the trim tools already Thank you for the pointers
Post #536859 9th Dec 2019 10:39pm
rjff
I know this concerns a tailgate, but the idea of a chafed wire in the ducting/gaiter may be worth a look if you don't find corrosion from water ingress
https://www.fullfatrr.com/forum/topic53695.html Cheers
Richard
Gap IIDBT
Post #536888 10th Dec 2019 11:07am
andyfid
Cheers rjff that could be a possibility as before you could hear the relay keep clicking as if something was earthing when you went over bumps before
Post #536893 10th Dec 2019 12:20pm
andyfid
Well fuel pump sorted gauge back.i replaced original pump with a genuine bmw one and put it back together doing that modification of chopping plugs and hard soldering the joints and it’s all working great now cheers Richard just got the windows to sort now when we get a dry day
Post #537297 13th Dec 2019 4:31pm
rjff
Great you got the fuel system sorted. Thumbs Up
Oh dear, now it's my turn Sad
Yup, took senior half of partnership out a couple of day ago and guess what? Her window isn't working on her door switch Rolling Eyes I suppose I could suggest she sits in the back like Lady Muck with chauffeur, but I'm not putting on fancy hat for anyone. Maybe something to do with having the passenger door window replaced earlier on after a stone break, perhaps the connectors a bit loose.
Let us know how you get on. Cheers
Richard
Gap IIDBT
Post #537301 13th Dec 2019 5:37pm
Balloonengineer
Both my rear windows stopped working.
To diagnose I pulled the plug and checked with the multimeter to see if any power was getting through.
On one side it was, so I took the door apart and the window motor had burnt out. Much easier to change than is described, about 30 minutes work to change the entire thing.
On the other side there was no power even though you could hear the relays clicking. so checked output close to the BCU, and still no power, so that discounted the wiring, and required the BCU to be repaired. Cheap and good fast service. I cant remember his name, but sure I put it on an earlier posting. Its likely the BCU failure caused the motor burn out.
Tip. (especially for those without kids!) Use the back windows every now again to keep them from getting tight as this puts a current strain on the BCU relays
Also make sure the rubber slides are kept lubricated with silicone spray.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #537349 14th Dec 2019 9:55am
andyfid
Well took apart the door to check see what’s up with the window and tested everything and got it down to the switch so looks like I will have to give rangerover a ring Monday and see how much they will sting me for a new one thanks guys for the heads up on everything very much appreciated
Post #538221 22nd Dec 2019 1:35pm
