![]() | Home > Technical (L322) > help needed |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i hope one of you guys may know whats going on .....my n/s headlight doesnt always come on some times i have to turn the lights on and off at least ten times before it comes on ....i thought maybe its a dodgy bulb so i brought 2 new ones that i fitted today ........suprise suprise its still doing the same thing ......please any ideas are welcome "RANGEISM WILL NOT BE TOLERATED"
slim_sane Member Since: 09 Jan 2011 Location: Kent Posts: 43 ![]() ![]() ![]() |
Try the ballast.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35530 ![]() ![]() |
as said , ballast [the silver box on the back] or the igniter [inside the headlight].....
when you say igniter inside the headlight ...where inside is it ? as that sounds like it could be the problem as once its been on it will turn on easy after that "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
ignore that last coment i think i know where it is now ..... i think its gonna be the igniter as my lights come on after a few goes so ill start by swapping the ballasts first see if it makes any differance ...thanks guys "RANGEISM WILL NOT BE TOLERATED"
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Pretlove - I had this and it was indeed the igniter. Its inside the headlamp held in with two T20 torx screws I renewed the bulbs also, in case any resistance from the bulb had caused the igniter to fail prematurely. See my post under xenon headlight components, many thanks to Reformed. The part is made by a firm called Automotive Lighting (AL)
thanks mate i think its definatley gonna be that so ill try and get hold of one and try that.....if you could give me the number for your auto elec as im having trouble finding a company that supply the igniter "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back ![]() |
