![]() | Home > Maintenance & Mods (L322) > Lower Front Trim Panels |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 906 ![]() ![]() ![]() |
You need to remove the lower panel - pulls off once you remove (or perhaps just loosen) one or two bolts (usually rusted solid) at the joint with the wing |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Thanks for that , Im sure there are 2 x screws at the top (that look very corroded !) , that needs to be undone. Trust it to be raining now |
If you can get a spanner on both ends, they usually end up snapping, 10mm from memory. |
Thanks , I will replace with stainless when I eventually get them off |
