![]() | Home > General (L405) > Does this car have deployables? |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 908 ![]() ![]() ![]() |
Looks like it does to me |
Bigglez Member Since: 17 Mar 2014 Location: London Posts: 156 ![]() ![]() |
THat's what I thought. I think the owner has switched them off and the dealers missed them as they were probably added later rather than as part of the build (they're not listed on topix - but then neither are the ones on the other car).
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for yes , maybe they have never been activated. 2015 4.4 AB
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes 100% it has them fitted... |
Well if Craig says it does!! That's gold plated right there. Thanks Craig!
I would be a little cagey in what you do as if the dealer finds them during PDI for example, they might just disappear ![]() ![]() |
Good point. At least I have video evidence! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
If you get pictures of the interior - there should also be a button down by the drivers right knee
pav911 Member Since: 28 Jul 2019 Location: Peterborough Posts: 23 ![]() ![]() |
I've had my car a few months now (2014 SC AB) and the deployable steps have been nothing but trouble. They have a mind of their own. The problem is intermittent so 2 trips to the dealer and they haven't figured out what the problem is.
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
A "PDI"........what a wicked sense of humour you have CTC. ![]() Next you'll be suggesting they will actually carry out their "165 point inspection"! ![]() If they missed a set of deployable steps, then that does not bode well for any other work that needs done. Mike |
If you can get the VIN then you can look at the build sheet & see if they were on there from new.
Actually the post above just reminded me...the car is in again for them to look at it and they said to me the steps aren’t covered under warranty as they are considered an accessory. I don’t know if the steps were on the car from the factory. |
Looks like I could be wrong on that - mine lists the deployable tow bar but not the steps - so they may be a dealer fit accessory rather than factory option..... |
